Is it possible to access mobile devices using local network (LAN) ?
Hello Ivan,
can you please specify what you'd like to do? Do you want to go from a mobile device to PC or from PC to mobile device?
If you want to connect to your mobile device via the TeamViewer ID, then this will work. However, if you want to connect to the mobile device via IP, then that is not possible at this point.
Rene
