Oct 10 10:10:10 macOS TeamViewer_Desktop[101]: InterProcessBase::HandleRetryTimer(): Retrying TCP communication (some processes failed to respond: 0 / 5)Oct 10 10:10:10 macOS TeamViewer_Desktop[101]: InterProcessBase:: StartTcpCommunicationInternal(): setting m_NetworkConnector to new TCP connectorOct 10 10:10:10 macOS TeamViewer_Desktop[101]: Opening local TCP connection to XXX.XX.XXX.XXXOct 10 10:10:10 macOS TeamViewer_Desktop[101]: Local TCP connection failed with error 61Oct 10 10:10:10 macOS TeamViewer_Desktop[101]: CTcpProcessConnector::CloseConnection(): PID=0Oct 10 10:10:10 macOS TeamViewer_Desktop[101]: CTcpProcessConnector::CloseConnection(): Shutdown socket returned error 9: Bad file descriptor
It still keeps running **bleep**.. unless you force quit it.. and then when it has "uninstalled" you now get this **bleep**:
Nov 19 08:40:36 eton-bor-mac30 com.apple.xpc.launchd[1] (com.teamviewer.desktop[49288]): Service exited with abnormal code: 78Nov 19 08:40:36 eton-bor-mac30 com.apple.xpc.launchd[1] (com.teamviewer.desktop): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.Nov 19 08:40:46 eton-bor-mac30 com.apple.xpc.launchd[1] (com.teamviewer.desktop[49292]): Service could not initialize: Unable to set current working directory. error = 2: No such file or directory, path = /Applications/TeamViewer.app/Contents/Helpers/: 19A602: xpcproxy + 14907 [673][799A5779-E2CE-33EB-81E8-3B5B047C0D40]: 0x2
I guess since nobody cares about this here's a guide to fully uninstall it https://www.quora.com/How-do-you-completely-uninstall-TeamViewer-on-a-Mac-OSX
As it still keeps running you have to remove this **bleep** manually also
get a list of stuff that needs to be stopped:
sudo launchctl list | grep com.teamviewerexample for stopping it:sudo launchctl remove com.teamviewer.Helpersudo launchctl remove com.teamviewer.desktop
Now kernel_task has dropped for me to an average 15%.. instead of 40-50%
50% average CPU it uses wonderful...
HELLO?? I guess this is why kernal_task is always at at least 30% CPU...
I quit 'TeamViewer_Desktop' but it seems to start itself again only after a few seconds... I have disabled start on boot but haven't restarted since.
Please address this issue guys, it's been a while..
I have MacOS Catalina (19A602)
Also, after uninstalling TeamViewer, the Console still reports the system logs mentioned above.
So something must be wrong here !
See Community Thread
