Dears, it is very hard to use team viewer pilot. I can't simply drag the arrows, some times they appear and some times not....
Very awfull...sorry for that.
I cannot work with him. I tested with another smartphone and it was worse, Pilot client crashes.
Is it possible connect my Pilot to your TeamViewer just to show you or your collegues how it works?
Thank youBest regardsLuca
basically the reference points shall only indicate where markers can be set. If there are a lot of reference points and you click somewhere near these points cloud, markers are set reliably. If there are very poor or no reference points, no stable markers can be set on this surface.
What would help you to work better?
Thank you & best
Friederike
Thank you for your prompt replay.I have done as you suggested. I can see reference points, but for a quick time, then disappear. It is very hard work in that way.
Best regards
Luca
you have to open the "settings" in the Pilot app and enable the function "Show surfaces and reference points". You can only place arrows where reference points or surfaces are detected. The displayed reference points and surfaces will help you to learn how object detection works and you accuracy of marking will improve quite quickly.
Dear Friederike, you posted on Nov 5, 2018 you would have implemented some features to better position the arrows, but it is March 27, 2019 and I cannot see any improvement.
If I am wrong, please let me know how to do or where to find some document to explain how to work with 3D markers.
Thank youLG
Same thing for me. I'm unable to create arrows or draw on screen. An arrow sometimes appears but it's maybe once of every 20+ clicks on the screen.
we are currently about to implement a function that allows you to show / hide feature points & planes. You can only set arrows on available feature points and/or planes. This will help you to better position your arrows.
See what's new at TeamViewer
