my monitor support 2560*1440 resolution, and i access the remote pc by teamview 14.but i cannot find the right resolution as following figure show. could you help me? thanks a lot.
Please support view remote computer from dual monitors that each have 2560x1440 resolution which would likely be a 2560*2 x 1440= 5120x1440. I don't know since I've never got it to work. The PC i'm remoting into doesn't have monitors but teamviewer thinks the max is 2048x12xx something. gosh frustrating.
https://community.teamviewer.com/t5/Community-Blog/Control-UHD-4K-Monitors-Remotely-with-TeamViewer/bc-p/65821#M503
https://community.teamviewer.com/t5/forums/replypage/board-id/TeamViewer_14
