ps. Can't remove or place this question in another Category..
Why don't I see the sharing option (recording is on)
Hello @J-f-rey
I recommend you to update the TeamViewer app.The screen sharing should work fine.
If it still does not work after the update, I recommend you to read the dedicated article about screen sharing of an iPad/iPhone here: How can I share the screen on my iPad/iPhone with TeamViewer?
Cheers,
