how can we define the same password for all clients. The clients should not be able to change or to see this password (****). This means that only and only our support can connect the clients through Teamviewer.
Thank you very much an advance
PW to login: Settings/Safety/Password
PW to protect the settings: Settings/Extended/TeamViewer-Settings (at the end)/Password
Thank you very much!
