I installed Teamviewer 14 on Windows 10. It started automatically but ID and Password are just a single dash (-). So TeamViewer does not assign ID for this device. What to do? I have internet and access to Teambviewer site.
Ivan
Hi,Access Control was set to Full control.Meanwhile I left TeamViwer started and began to install it on several other computers . It took me about twenty minutes to do that. Then I looked at that first PC without ID and saw that ID has appeared. I think that some network trouble took a place here....Now it is OK and working.
Thanks.
Hi @jwalkerbg,
Can you please have a look at your settings?
You find the respective option under Extras --> Options --> Advanced --> Advanced settings for connections to this computer and have a look at the Access Control. Incoming connections should not be denied - the best would be Full Access Confirm everything with OK.
Please let me know, if this could help.
All the best,Natascha
