Currently using teamviewer version 14.2.2558
3 different computer login teamviewer 14 always show Not ready. Please check your connection.
May I know how to resolve this issue?
Restarted TeamViewer. Did not help. Still says "Not ready. Check your connection"
Hello @JasonSeah,
I recommend you to restart the TeamViewer service.
-Execute run, type services.msc and press OK
-Now find TeamViewer, and restart it by doing a right click.
Then, restart the TeamViewer application. It should work again.
Best regards
Jean Kinzler
