The remote control password is simply a dash. Attempting to refresh/reset the password does not help. Any ideas?
Hi @JimKaram
Sounds like your random password is disabled.
You can choose the complexity of the password strength in your TeamViewer application under Extras--> Options --> Security --> Under Random Password (for spontaneous access) --> Password strength --> Set your password strength to e.g. 6 characters --> Click OK.
I hope this info helps you and others who might face the same situation.
Best, Esther
