The timing out of inactive sessions-function isn't working. It's set for 8 hours but always disconnects after 4 hours. What might be the problem?Thanks on beforehand!
Hello! I replied to your question but haven't heard from you in a while.
The specifications are mentioned in the post above.
bump
OS is win10, TV version 14.2.8352 on both comps
Hi @mrscheng ,
Thankyou for your post.
Can you kindly provide the information of TeamViewer versions and operation systems from two sides of the connection please.
