When I update win10 to 1903 today and found that the teamviewer cannot work correctly. I can built the connection but the screen is totally bluck and I canot see the desktop of the remote computer. Hope the team can fix the problem, thanks
Hi folks,
same to me. Remove Duet Software fixes the problem.
Best RegardsMark
My problem fixed by removing Duet (an app to make iPad an external monitor). See it helps in your case.
Hello bro, the screenshot is the exactly the same as the problem in my laptop and hope the official team can solve it later, anyway, thanks for your reply.
The problem didn't happen to all computers. I have my HP Spectre X360 has this problem, but not my Dell OptiPlex 7050. Not sure if it is the display adapter problem.
