As mentioned in the subject, everytime I end the Teamviewer 12 session, it reboots the PC. Can anyone explain me why?
The pc is running Windows 7 embedded.
Any luck with running on Windows Embedded? I upgraded all PC to the last version but later realized that I cannot do it on the Windows Embedded PC and now I cannot connect there because the versions are not compatible!!
On Windows Embedded PC there installed version 8.0.44109. Tried version 8 stand-alone but no luck.
Hello Claus
Unfortunately, I can not help you with your problem.
I think you can help me.Which version, installation file do you have installed on your Windows Embedded Compact 7 device? I've been looking for a TeamViewer version for Windows Embedded Compact 7 for a long time.
I hope for an answer from you.Thank you for your efforts.
It is the remote PC
