Hi Community.
Is it possible to use api without going through the team viewer login page ?
Can I get the code without going through the login page?
Cheers,
Bernardo
Hello Bernardo,
unfortunately I don't understand what you mean with "without going through the team viewer login page".Could you please try to describe what you are trying to achieve?
You can create a token for a user and use this without a login at the Management Console.
