I have certified that the settings are all ok with automatically starting the program when I start or restart my PC. Has always worked until last 4 days. Any ideas?
Hello @OtanDear,
Could you please check if the TeamViewer service of your device is on Automatic?
If not, please set it on Automatic and press OK.Now, restart your device and see if TeamViewer starts automatically with the system.
Let us know if this has fixed your issue. :-)
@OtanDear,
this is great to hear! :-D
We hope to see you soon in the Community.
Have a great rest of the week.
It opened!! Thank you so very much - just a bit of an annoyance:)
I found the services - and it is set to automatic I will try to restart it again and see what happens.
I do not have that screen - or can't find it. When looking at properties for TeamViewer_service.exe it is not an option. Should I go to services instead of this location? And why would the "start with windows" not work?
