The text on my teamviewer screen has changed to the point I can no longer read it. Either that or the background color has changed making the contrast illegible. I tried reinstalling TV, and still got the same problem. Is there a way to fix this?
That didin't fix it. The problem is I updated my version of Windows Insider build to v.18970. This is obscuring a section of the desktop on the teamviewer App. Hopefully the next update will fix this problem. Maybe someone on the teamviewer end could take a look at the problem?
Hello @Ligomiego
I recommend you to change the interface to the light mode.
You will find all the information you need in our Knowledge Base article here: Disable Dark Mode
Cheers,
