as the Topic sais. how can i remove a Computer completely fro my Account ?havent found anything
OK,
but how it is possible to delete all contacts in a group. I ordered my contaczts and create a group named todelete. Now I plan do delete all members of this group.
i @Druzil
You can remove a contact by right-clicking on the single entry.
If you are the one who provides support and you do so by sending a QuickSupport module or an Host module, you can configure the latter to NOT automatically save the contacts at the end of the connection
I hope I understand your request and that this can help
