Hi
I installed teamviewer IoT. the version was proposed byu default in third party packages.
Hower I get this message and I get no id nor password to assign to my account
anyone a solution ?
run on a DS214+ Marvell Armada XP MV78230
Thx
Hi Vatsilidis
yes, it worked thanks
I finally joined the domain and the DNS has been set by default (ip of the DC controller)
Hi @aquaconfort
You still facing the issue?
Hi, have you setup DNS server and Gateway for make it accesible online?
If this worked for you, then it maybe useful for future users to look directly at your post, if you mark it as solved.
Best regards
@aquaconfort
Did you found some time to check my solution?
not tried yet
i will inform
thx
not tried yet (not have had time to test)
I will inform once done
See what's new at TeamViewer
