Hey all, I’m running TeamViewer Host on a Lenovo tablet, and after the tablet starts, I’m unable to connect.
I can see it in the management console, but when I try to connect it says that TeamViewer isn’t running.
I see. And are you sure that TeamViewer is running on the remote device?
Do you have the device in front of you and did you click on the TeamViewer Host to run it?
Yes, the connection is fine. It's able to access the Internet (Chrome, Gmail notifications, etc)
Hello @DJQuad
If the connection on the remote side is stable and working, it should work fine.
Have you checked the connection on the remote side?
Yesterday I reinstalled Host and was able to connect, however today I cannot.
TeamViewer or TeamViewer Host? I do need unattended access.
We recommend you to uninstall the Host and to reinstall the latest version from the Play Store or from our website. And to try again, to see if the issue persists.
Cheers,
See what's new at TeamViewer
