Hi there!
I've tried to download TeamViewer for my Debian Jessie 64 bits.
In the download page says that your download is multiarchitecture, but I only get the right version changing the download link from "i386" to "amd64".
Please, fix it.
Dear gothedufranca,
What we mean by 64-Bit Multiarch is that your 64-bit distribution must have multi-arch installed.
To verify this run the following command:
dpkg --print-foreign-architectures
The output will display the architectures installed on your system.
To add the i386 architecture to your system please run:
dpkg --add-architecture i386sudo apt-get update
Once you have this architecture setup, you're able to install TeamViewer.
However, I will forward your suggestion to the respective channel.
Hope this solution works for you.
Christian
See what's new at TeamViewer
