I purchased a Business License but every endpoint I try to connect to gives me the "Commercial Use Detected" Msg.
Yes I am using it Commercially but I purchased a license. Why doesnt it reconize this?
Hi @bob1285
Please make sure, that you are using the same TeamViewer version on both devices accordingly to the license version you are having.
For example: If your Business-license is valid for TeamViewer 10, please use TeamViewer 10 on your device and the endpoint. If your Business-license is valid for TeamViewer 9, please use TeamViewer 9 on your device and the endpoint. And so on.
If you would like to work with TeamViewer 12, you can update your license in our webshop.
All the best, Esther
I do have a business license on one pc but when I try to access an endpoint pc it gives me message "commercial use detected and will boot me off after 5mins
Please tell me what I am doing wrong and how to solve this issue.
Hi bob1285,
in this Knowledge Base article you can find out how to activate your Business-license on your devices: How to activate Business license
You just need the license on one side of the connection to have a licensed connection. This should solve the issue for you.
Best, Esther
See what's new at TeamViewer
