After Updating from Windows 7 to Windows 10 Teamviewer changes the ID every time I start the computer. When I login with my account then I have to confirm each time the link in the email. Also I cannot connect from remote because the id changed.
I changed permissions in the registry of HKEY_LOCAL_MACHINE\Software\WOW6432Node\TeamViewer to Everybody full access, but the problem ist still the same.
The account has admin rights, but I did not explicitly start the setupt with right click "as administrator". Should I do that?
Or: Where is the id stored? If I know I could try to change the permissions.
Did you install TeamViewer as an Administrator on that computer? That ID is usually stored in the registry I think. The only reason it would be changing is because it is unalbe to be stored.
Your ID
Let me confirm, Is the "Your ID" changing or the Password?
See what's new at TeamViewer
