In the FAQ you mention that you are working on a solution to copy monitor configurations between Monitis and TeamViewer Web Monitoring.
Do you have a timeline for this?
Hi, prabash-mdosl,
Please find the migration tool on the Add Monitor wizard
Hi Team/ @Karlen ,
kindly let us know where we can find mentioned feature.
I look forward to hearing from you at your earliest convenience.
Thanks,
Prabash
You are kindly requested to inform the availability of the mentioned migration tool .
Hi, beeba,
Good question
probably I had to be more precise.
The mentioned month was October 2020. The feature I was talking about is released and is reachable.
ah, the end of the month. Which month?
Hi prabash-mdosl
Thanks for your patience and sorry for the inconvenience!
It will be ready at the end of the month
Karlen
Hi @Karlen
Is menioned Migration tool ready ? .Kindly let us know.
The Migration tool is not ready yet we are still working on it, as soon as it will be ready we will also provide some detailed guidance on how to use it.
Is this feature realsed now and kindly let us know where can we find it ?
Futhermore ,will you able to provide detailed guidance for migration to TeamViewer Web Monitoring from Moinitis .
Hi sgibson.
Thanks for using Monitis!
We are working on this feature now and plan to release at the end of September. As of your account, after the subscription ending you will be automatically moved to grace period and can use your account, so that you will be able to move your monitor configurations from Monitis to Web Monitoring,
Is there an update on this feature? Our Monitis account will be deactivated on Sept. 11th and we need the TeamViewer Web Monitoring setup immediately.
Hi kyu
The estimated release for the mentioned functionality is mid of September, but these days Monitis users will have possibility to download the new configuration dump (implemented to sync with Web Monitoring, for Uptime and Page Load monitors) from Monitis and also the Transaction monitoring scripts from Recorder to move them to Web Monitoring.
You can keep the configuration dump file on your local drive for later uploading it to Web Monitoring.
Any update if this is availible yet
Hi kyu,
Thanks for asking, we plan to have this solution in August this year
See what's new at TeamViewer
