Here is my team viewer screen,
How to set a full screen?
@JeanK Yes, i tried that but no use, still the same size. Is any setting change from end-user Teamviewer settings.
@JeanK wrote: Hello @Gta,Thank you for your message and welcome to the TeamViewer Community! ?I recommend you to try the three scaling buttons on the left side of the View panel and find out which one fits the best on your local screen: I hope this could help. ?If not, do not hesitate to ask your questions here. ?Best regardsJean
Hello @Gta,
Best regards
