High Audio Output
Running TV 12.0.78517, the latest. When I connect to any remote sessison the audio output on my local machine dampens, so I compensate by increasing my volume. When disconnecting remote session audio returns to original level plus the level that I boosted, thus nearly blowing my ear drums and giving me a heart attack - every time! I have tried disabling remote audio (I don't need it), and killing all local audio settings in the TV app but nothing seems to work...
  • bartlanz
    bartlanz Posts: 315 ✭✭✭
    Go to Options > Audio Conferance and adjust the Volume settings, There are two of them. Not sure which you want to play with. If you could tell me wich one I'll know next time.tv Audio Conf.png
    Bart Lanzillotti
  • Many thanks for the reply however this didn't help. I have tried various configurations from this menu, raising/lowering both sliders, changing output device from "built in output" to "standard playback device" and nothing helps. In fact when I open preferences and select the audio tab the volume of my Mac decreases significantly, showing the same symptoms as when I open a session to a remote. I wonder if this is specific to me only?!
  • Pgagnon
    Pgagnon Posts: 2
    I also have the same problem, I am really bored of this since I do remote support all day and listen to internet radio at the same thing.. I hope this will be fixed soon..
  • Pgagnon
    Pgagnon Posts: 2
    FYI I found a temporary fix, I just disabled my microphone in the computer settings of my computer and it stopped doing this problem.
  • Deadlock
    Deadlock Posts: 4
    @bartlanz   cool and user friendly solution.
    Thanks in Advance
    R.A.
