Which licence include switch side feature?
alberttran
alberttran Posts: 1
edited May 2 in Licensing
I have a case as below:
The Source Teamviewer user connect to the Destination teamviewer -> then the source Teamviewer user can see the screen of the destination Teamviewer.
Then I would like to use "switch side" for the destination Teamviewer user can see the screen of the source Teamviewer. Who can click the switch side.
So in this case, can you please advise which user (the source or the destination) should buy the Teamviewer license and which license is suitable?
Thank you so much.
  • Fiona_G
    Fiona_G Posts: 689 Staff member 🤠
    Hi @alberttran,
    Thank you for your message and welcome to our community.
    The feature of Switch sides with partner is available for private users. For more information, please check out - All about the TeamViewer Remote Control Toolbar
    Regarding the benefits of having a subscription, please kindly refer to -
    All about Subscription
    What TeamViewer license do I need?
    Alternatively, you can contact our sales team, they will be happy to advise you on your options.
    I hope the information would be helpful.
    Kind regards,
    Fiona
    Fiona_G
