copy monitor configurations between Monitis and TeamViewer Web Monitoring
In the FAQ you mention that you are working on a solution to copy monitor configurations between Monitis and TeamViewer Web Monitoring.
Do you have a timeline for this?
Hi kyu,
Thanks for asking, we plan to have this solution in August this year
Product Owner, Remote Management services2 -
Any update if this is availible yet
Hi kyu
The estimated release for the mentioned functionality is mid of September, but these days Monitis users will have possibility to download the new configuration dump (implemented to sync with Web Monitoring, for Uptime and Page Load monitors) from Monitis and also the Transaction monitoring scripts from Recorder to move them to Web Monitoring.
You can keep the configuration dump file on your local drive for later uploading it to Web Monitoring.
Product Owner, Remote Management services0 -
Is there an update on this feature? Our Monitis account will be deactivated on Sept. 11th and we need the TeamViewer Web Monitoring setup immediately.
Hi sgibson.
Thanks for using Monitis!
We are working on this feature now and plan to release at the end of September. As of your account, after the subscription ending you will be automatically moved to grace period and can use your account, so that you will be able to move your monitor configurations from Monitis to Web Monitoring,
Hi Team/ @Karlen ,
Is this feature realsed now and kindly let us know where can we find it ?
Futhermore ,will you able to provide detailed guidance for migration to TeamViewer Web Monitoring from Moinitis .
Thanks,
Prabash
Hi, prabash-mdosl,
The Migration tool is not ready yet we are still working on it, as soon as it will be ready we will also provide some detailed guidance on how to use it.
Karlen
Thanks for your patience and sorry for the inconvenience!
It will be ready at the end of the month
Karlen
ah, the end of the month. Which month?
Hi Team/ @Karlen ,
You are kindly requested to inform the availability of the mentioned migration tool .
Thanks,
Prabash
Hi Team/ @Karlen ,
kindly let us know where we can find mentioned feature.
I look forward to hearing from you at your earliest convenience.
Thanks,
Prabash
