Autoassignment Tool with TeamViewer 12 and proxy
We're trying to deploy TV v12 with Autoassignment tool.
When we tried to register the device with the tool, we meet that issue :
C:\Users\administrateur\Desktop>TeamViewer_Assignment.exe -apitoken MY_ID  -datafile "C:\Program Files (x86)\TeamViewer\AssignmentData.json"
TeamViewer_Assignment (r341)
=> Assignment failed with:
Get https://webapi.teamviewer.com/api/v1/devices?remotecontrol_id=r962270909: di
al tcp 65.52.140.72:443: connectex: Une tentative de connexion a échoué car le p
arti connecté n’a pas répondu convenablement au-delà d’une certaine durée ou une
connexion établie a échoué car l’hôte de connexion n’a pas répondu.
The tool need to go through a proxy to connect to Teamviewer webapi.
Is there a way to add an option to indicate to the tool that we need to use a specifific proxy server.
Note : The device used is already connected with the proxy in Windows Proxy options for http and https connections (its works already with browsers).
Thanks for your help.
DG
  • Hi
    UP ...
    any idea ?
    How to make to autoassignment tool work with manual proxy ?
    ThanX.
  • Hello,
    the current Assignment tool doesn't support a connection via proxy server automatically.
    We are planning to release a new version of it which will support this.
    Please try it this way:
    TeamViewer_Assignment.exe -apitoken {YourToken} -datafile "%ProgramFiles(x86)%\TeamViewer\AssignmentData.json" -verbose -proxyurl https://{Proxy_Username}:{Proxy_Password}@{Proxy_Host}:{Proxy_Port}
    Christian
    Team Lead Product Development (Enterprise)
    Did my reply answer your question? To help others, please accept it as solution. Thanks!
  • Hi Christian,
    Thanks for your reply.
    The option -proxyurl does't doesn't seem to work. Besides this, there are no credentials on our proxy . I get this result when I tried to execute it :
    (I tried with and without quotes surrounding proxyurl parameter)
    C:\Users\admin>\\domain.local\netlogon\TeamViewer_Assignment.exe -apitoken XXXXXXXXXXXXXXXXXXXXXXX -datafile "C:\Program Files (x86)\TeamViewer\AssignmentData.json" -verbose -proxyurl https://192.168.1.210:8080
    flag provided but not defined: -proxyurl
    Usage of \\lsa.local\netlogon\TeamViewer_Assignment.exe:
    -allowEasyAccess
    Allows easy access (optional) (default true)
    -apitoken string
    Token for API-Access (optional, if not contained in AssignmentData.json)
    -apiurl string
    Root-URL of the TeamViewer-API (optional) (default "https://webapi.teamviewer.com/api/v1/")
    -datafile string
    Path to JSON-File 'AssignmentData.json' (required, environment variables are resolved when specified in the form of ${var})
    -devicealias string
    Alias for the new device in the partnerlist (optional, if omitted the host name is used, if "" is passed the TeamViewer-Id is used, environment variables are resolved when specified in the form of ${var})
    -verbose
    Verbose output (optional)
    -wait int
    Time to wait in seconds for the file specified with the -datafile parameter (optional, default is 10 seconds) (default 10)
     Any idea why the option -proxyurl is not active ?
    thanks !
  • Hi damienghandour,
    we released a new version of the Assignment Tool this week, please download the latest version and try it again.
    Christian
