MSI deployment and account assigment without easy access
How do I assign my devices to Teamviewer Account without granting easy access via MSI and CMD/Powershell?
How will it work with GPO?
Gintaras
    Hello @Gintarasp2,
    In order to deploy TeamViewer without Easy Access, you only need to make sure that you don't add the Easy Access parameter in your command line.
    Here are two examples:
    Without Easy Access
    msiexec.exe /i "<Path>\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=<Your_Config-ID> APITOKEN=<Your_Apitoken> ASSIGNMENTOPTIONS="--alias %COMPUTERNAME%"
    timeout /t 5
    net stop teamviewer
    net start teamviewer
    With Easy Access
    msiexec.exe /i "<Path>\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=<Your_Config-ID> APITOKEN=<Your_Apitoken> ASSIGNMENTOPTIONS="--alias %COMPUTERNAME% --grant-easy-access"
    timeout /t 5
    net stop teamviewer
    I hope this could help. ?
    Best regards
  • Gintarasp2
    Hello JeanK, That is what I used to do to enroll device with --easy-access.
    However if I use you suggested line:
    timeout /t 5
    net stop teamviewer
    I wount not get device assigned to account:
    https://ibb.co/x6xWt2t
    Hello @Gintarasp2
    Thank you for your message. ?
    As this is not expected behaviour, this needs to be analyzed by our engineers.
    I recommend you to open a ticket, our engineer team will be happy to look at your logs and help you further: https://support.teamviewer.com/a/
    Best regards
