Screen freeze
When I connect to my home pc from my work pc after 10~15 secs my screen is freeze completly and I can´t use anymore the remote desktop, I dont know what happen with older version this issue never happen.
I'm using windows 10 in both machines.
My only work around has been to log off the remote and log back on. It updates the screen and sort of works ok for a while.
It appears they have just released (29/11/2016)an update to the Beta software that addresses this issue. I haven't tested it yet but what's to lose? Check for updates.
I'm facing a similar problem, using TV 12 final, but it already appeared to the same remote-machine with TV 7, too.
I can connect and everything runs fine at first, but just trying to collapse the small TeamViewer-window in the right bottom corner freezes the screen.
This just seems to happen in our company network, the problem doesn't appear using a mobile LTE-connection. Does anyone have any hints to solve this?
