cannot connect to teamviewer server (Nov. 25th, 2020)
My access has been working fine and suddenly I get this message.
I've switched my router on & off as this has worked in the past but not this time.
No other internet issues
Not had any Windows updates recently.
Help!
  • Esther
    Hi @josmith447
    Thanks for your report!
    Where are you located?
    Thanks,
    Esther
  • Hi
    Manchester M46
    Just saw your connectivity issue message so I'm guessing that's related
  • Hello Esther,
    I am in Essex in the UK, and we have issues, our client is in Telford in the UK, they also have issues, exactly as @josmith447 described.
    But, it seems that established connections are fine, just new connections, don't authenticate with your servers.
    Hope that helps.
    Roy
  • alemc
    alemc Posts: 1
    me too....
  • posix
    posix Posts: 3 ✭✭
    Google DNS (and perhaps others) can't resolve Teamviewer DNS.
    C:\Users\user>nslookup router10.teamviewer.com 8.8.8.8
    Server: dns.google
    Address: 8.8.8.8
    *** dns.google can't find router10.teamviewer.com: Server failed
    same result from https://toolbox.googleapps.com/apps/dig/#A/
  • It's ok for me now
  • Yep, back online again!
    Thanks Guys & Girls!
    Roy
  • Esther
    Thank you for your reports so far!
    We immediately gave all info to the devs.
    Let´s hope it´s all resolved now. You can keep track of the status here: https://status.teamviewer.com/
    Best, Esther
