Web monitoring failed
ronenb
Posts: 1 ✭
We've Recently transfered all web monitoring rules from monitis.
its seems that most of our web monitoring are failing to check the string test
which is configured same as monitis.
only diffrence is that in monitis we can choose http version (which doesn't exists here)
Any Suggestion?
Thanks,
Ronen.
Hi, ronenb,
Thanks for using Web Monitoring!
Sorry for the inconvenience, we will try to understand and fix the issue.
In Web Monitoring, there is no need to select the HTTP versions as all is done automatically from the back-end.
Product Owner, Remote Management services0
