Team Viewer Host 14 check for update
kaucky
kaucky Posts: 4 ✭✭
Hello, I use TV 14 and all host has Check for new version and Install new versions automatically grey field, cannot change parameter.
The same situation is with mass deployment or manual install.
Some idea?
Thank You
Jan
    Hello @kaucky,
    There is probably a policy that forces this setting.
    You can check it by doing this:
    1. Connect to your TeamViewer company administrator account via your Management Console
    2. Go to Design & deploy and click on Policies
    3. Edit the policies and check if there is the parameter set upAuto_update1.png
    4. Edit the parameter and untick Enforce
    5. Save
    This should allow you to edit the settings again.
  • kaucky
    kaucky Posts: 4 ✭✭
    Thank you for a reply, but still the same. And Remote update from console to connected client doesnt work too.
    Hello @kaucky,
    Then, it could also be a bug in the installation package you have installed.
    I recommend you to uninstall completely your TeamViewer client and clear the registry by following the procedure explained in this article: How to uninstall TeamViewer on PC
    And then, reinstall the client again.
    I hope this will work.
  • kaucky
    kaucky Posts: 4 ✭✭
    Thank you, but still the same.
    It is clean install without .reg file only msi from Console. I tried to made new host config and still same...
    Jan
  • ysystems
    ysystems Posts: 3 ✭✭
    edited January 2021
    This is because you installed the MSI version. For whatever **bleep** reason they disabled this option for MSI installations ONLY.
