RaspberryPi4 displayed as online but cannot access anymore
Markovicz
Markovicz Posts: 9 ✭✭
edited February 2021 in Linux only
Dear Teamviewer-Community,
I am accessing a couple of RPI4 over Teamviewer and occasionally I cannot access them anymore though they are still displayed 'online' for several hours.
The error on Tetamviewer is simply:
No connection to partner
Error: Wait for connect failed
The application I am running on it got also stuck (I can see that over the internet) so the actual 'freezing' is not a problem of Teamviewer but the RPI got stuck and TV still displays it as online. Do you have any troubleshooting ideas?
Thank you!
So eventually
  • Lachim76
    Lachim76 Posts: 1
    I am experiencing with same situation.
    What I have recognized, this can happened, when your HDMI device is disconnected. Once connected, and reboot done, the connection works fine again. But this is something I would like to get fix, and do not know how.
    So any advice appreciated.
  • Ambiosfera
    Ambiosfera Posts: 0
    Same for me.
    Lachim76 is right, it work when you connect some kind of monitor or TV, but I have no monitor for all my remote Raspberries!
    Any thoughts?
