Android: mouse pointer is shifted
Hi there,
I wish to remote maintenance a Galaxy Tab A7 (SM-T500, Android 10, Knox 3.5). I installed TeamViewer QuickSupport on the tablet.
Problem: I can see the tablet's screen content. But my clicks are not where the mouse pointer is shown to me.
This means: For example, I point to "Contacts", but the "Calendar" opens.
Can anyone help?
Regards, KIlombo
  • KreeBraden
    I'm experiencing the exact same issue.
    What works:
    * I am able to connect using QuickSupport and see the screen
    * I am able drag the screen left and right by clicking and dragging
    What doesn't work:
    * I'm unable to tap on things on the tablet screen -- clicking with the mouse seems to not tap on the corresponding spot on the tablet screen. I've experimented a decent amount and have not been able to figure out if it's consistently off in one direction.
    * Screensharing via the TeamViewer Host app doesn't appear to work -- when I try to connect via I'm able to send keystrokes to it, but the screen is black.
  • RBrent
    RBrent Posts: 1
    Same problem here with macbook air
