Mouse left-click and hold
I am controlling a windows pc remotely using an Android phone. I need to be able to left-click on a button and hold it down for a while while an action takes place. Is there any way this can be done?
Many thanks,
Neil.
  • Parkimedes
    @Coastliner This is the problem I'm having! When I am clicking around and dragging a lot, using 3D software, often when I let go, it thinks I'm still dragging. Its this feature, where the second click holds even when I let go. Is there a way to turn this feature off?
  • Chris1600dat
    Chris1600dat Posts: 1
    I am also having this issue, when working remotely any click that I make on a mouse it will always hold the click until I can click slowly to release the click. Very frustrating and difficult to use.
    Any way to turn off the click hold?
