I got this message , so it seems they are working on it :)
"We already reported this to our platform provider to change it, but they are still working on it."
I would think that if you use it too much this is what happens. Leave it a few weeks and you will probably be able to login for longer.
As I hardly use TV due to them not replying to my application for Commercial use to be reviewed and removed I can now use it on the rare occasion I need it.
I doubt it, this is nothing new....
2 -
I am a seldom user of Teamviewer free edition, all my own machines (Laptop, Tablet, 2 Desktop PCs)
My latest session ended after 60 seconds and I could not reconnect even after waiting the one or two minutes that the mesage mentioned.
Is a free use not possible anymore?
4 -
Hi I'm trying to fill out your page but it seems like the submit button is failing to call a javascript library
Action -> Generate PDF
Page -> "Can I get my TeamViewer ID reactivated?"
URL -> https://www.teamviewer.com/en/reset-management/
Error -> DevTools failed to load SourceMap: Could not load content for https://www.teamviewer.com/wp-content/themes/tv-wordpress-theme/dist/js/pdfmake.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
Thanks!
I have the same problem. I use really rarely, and I have opened it up now, only to connect to my PC upstairs.
I had this problem previously, teamviewer people unblocked it for me, but i forgot what was the procedure, happened last summer.
But i am getting tired of this.
I think i will just switch to the nuissance called windows Remote Desktop Connection
I'm using the free version of Teamviewer to check up every now and then on my personal computer at work.
However, lately I'm having issues with connecting. After a couple of minutes/seconds I get kicked out with a pop-up that the session timed out. When trying to reconnect it gets refused because I have to wait a couple of minutes because of the free license.
Any advise here? I never had this issue before. For info: both computers are running the latest version.
Laurens/Mako313
i have the same problem.
I've been using your program for quite some time and I'm happy with it. there is a need to use it 1-2 times a week or even less often. I can't understand why I was suspected of commercial use. Once I was helped by the bank's support service to solve problems with their program and you thought that it was me who was engaged in commercial activities, but we solved this issue together (thank you!). However, now there was no such difficult situation and I was restricted access to my computer. Please help me deal with this problem..:) Thank you.
Since a couple of days, the connection is closed after less than 1 min. I'm using a free version for personal use, no commercial.
Any reason for this? How to solve?
Adel
I have the same Problem
Me too.
Mee too. And it doesnt't allow to connect.
I have the same issue :(
I'm having the same problem since Friday 19 March. Bit of a bumma as my 87 year old mother-in-law frequently needs some "guidance" with her PC. Hope it's fixed soon - I submitted a ticket yesterday but no response as yet.
Haha adygolfman I use it for my 86 year old Mum!
I have the same problem with the PC of my mother, but she is "only" 74
when I connect to my partner everything seems to work fine, but about 30 seconds came timeout and connect will be lost. Whats the problem? I haven't get this problem never earlier?
Thanks for your answer
t. Petteri
Hello, my free access has been blocked to 1min for no reason.
I don't user teamviewer for professional use, it's purely personal, how can I get back my free access?
I depend fullly on personal support from a familiy member trough Teamviewer. But since a few days, the connection is dropped after max. 1 minute (Timeout). After that, it is not possible to reconnect for at least 15 mins. This is a major problem for me. Please help.
I have the same problem since a few weeks. Like you I never received an answer from TV with the result that I deleted my free account with them.
Please assist.
Please assist.
I keep having the same issue. 1 minute sessions with a 5 minutes lockout period following.
If it keeps this way I will install VNC, does not have all the features but it works
Me too. Using for the mom and a friend with mental retardation.
Hi
I am using TeamViewer to support my 83 year old dad. Its worked great for years until today. Now I get kicked off within less than a minute with a message telling me that it is blocked or timed out and that my (non-commercial) license only allows for one connection at a time. But I am only using one connection.
I updated to the latest versions and rebooted both machines but I still get the same message. Can you guys point me towards a resolution of this problem?
Best regards
Lars
I have had this situation for a couple of weeks now.
Followed the instruction and asked online for opening my license. Sent in the signed document. No change. Attempted this two times. Still the same.
I have been using TW for several years purely for hobby purposes. I give help to friends when they have problems with their digital ham radio communication. My usage pattern has not changed over the years. I used it very infrequently, except when some problems persisted, and extended help was required.
Is there any hope in getting permission to use it normally again?
Per-Tore / LA7NO
for a long time, connecting with another person lasts less than a minute! I have to use other companies. Please fix the problem.
Go to Teamviewer.com/en/reset/ and fill in form with your ID on Teamviewer , put in comments that you only use for private
and send
wait few days eand then you get mail
Same problem here as reported by this and other users.
This time no mention of "suspected commercial use" (as I received two years or so ago, but after couple of months of waiting and 3 declarations of private use... the restriction was lifted).
Only possible reason is I have spent significantly more time on TeamViewer helping during recent days with my old school friend - (tutoring, setting up, maintenance of his PC and phone ... he is absolutely IT illiterate). Private use.
Any idea what to do?
Same problem since yesterday (March 19th) here.
I use TeamViewer to help my family members and friends (often older people and IT illiterates) - that's private use I think.
I have to say I spent more time on TeamViewer in recent days helping my old school friend with setting up his PC and phone and some tutoring (he is a real IT illiterate).
I have the exact same issue. It is really frustrating and I can't help my relatives any more!
Does anyone know why? Is there a way to fix it?
