Mass Update of v15.14 to current Version (v15.16)
skane
skane Posts: 8 ✭✭
I am planning on my first Mass update of TeamViewer Host and Full clients from 15.14 to the current version.
Has anyone done this on a large quantity of computers (more than 1000)? Can I simply run the update by updating the client with the MSI installer or do I need to reassign using the API Token and CUSTOMCONFIGID switches?
Thanks in advance,
Sean
    Hello @skane,
    We recommend updating all your clients to the latest version via TeamViewer policies.
    The policies you need to add are:
    • Install new versions automatically with the parameter All updates (includes new major versions)
    • Check for new versions with the parameter Weekly
    You will find all the information you need about TeamViewer policies in our Knowledge Base article here: How to add a new settings policy
    I hope this could help!
  • skane
    skane Posts: 8 ✭✭
    Hi @JeanK , what happens if the end user does not have administrative rights on their computer? Will it still be able to perform the installation?
    Hello @skane,
    Yes, the installation will proceed even on non-admin computers.
    However, if TeamViewer has been initially deployed via .msi, the policy won't work.
  • skane
    skane Posts: 8 ✭✭
    Ok thanks @JeanK - I did use the MSI Installer as part of the Mass deployment. Not sure of any other way, didn't realize you could register the EXE deployment with our client ID.
