Repository is no longer regarded as secure. No Update possible (Fehl:31 https://linux.teamviewer.com
2
  • jdrch
    jdrch Posts: 10 ✭✭
    Can confirm it's fixed on my end. Thanks!
    TeamViewer on 5 Windows PCs, 4 Linux PCs, & 2 Android smartphones
  • Temmokan
    Temmokan Posts: 0
    Confirming, on my side it looks working again (after running "sudo teamviewer repo stable ; sudo apt-get update -y")
  • jnq35
    jnq35 Posts: 0
    Hello all, I confirm problem solve on ubuntu for me. Thanks.
  • donal_
    donal_ Posts: 0 Newbie
    Confirmed for Debian 10 too.
  • QPG
    QPG Posts: 23 ✭✭
    Confirming that 'zypper ref' is working properly today on OpenSUSE Leap 15.2 for me.
  • Cyberdoc
    Cyberdoc Posts: 1
    Linux Mint 20.1 works again - Thank you!
  • rolandg
    rolandg Posts: 66 ✭✭
    works again. thx
  • fips
    fips Posts: 8 ✭✭
    Working again. Thanks!
    JeanK Posts: 6,888 Community Manager 🌍
    Thank you all for your responsiveness...
    You guys are awesome! ❤️
  • Helio2k
    Helio2k Posts: 1 Newbie
    Unfortunetly this morning I am getting the error 404
    Running OpenMediaVault 5
    any help would be great
  • tobiasperschon
    tobiasperschon Posts: 1
    currently its broken again.
    Err:3 https://linux.teamviewer.com/deb stable InRelease
     403 Forbidden [IP: 99.86.242.28 443]
    Reading package lists... Done
    E: Failed to fetch https://linux.teamviewer.com/deb/dists/stable/InRelease  403  Forbidden [IP: 99.86.242.28 443]
    E: The repository 'https://linux.teamviewer.com/deb stable InRelease' is no longer signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
  • Sab1703
    Sab1703 Posts: 4 ✭✭
    Hi !
    Have got the same trouble.
    OS: UBUNTU 20.04 LTS
    TEAMVIEWER version : 15.19.3
    Err :7 https://linux.teamviewer.com/deb preview InRelease
     403 Forbidden [IP : 2600:9000:2113:5e00:1c:3aaa:b100:93a1 443]
    E: Impossible de récupérer https://linux.teamviewer.com/deb/dists/preview/InRelease  403  Forbidden [IP : 2600:9000:2113:5e00:1c:3aaa:b100:93a1 443]
    E: Le dépôt https://linux.teamviewer.com/deb preview InRelease n'est plus signé
    N: Les mises à jour depuis un tel dépôt ne peuvent s'effectuer de manière sécurisée, et sont donc désactivées par défaut.
    N: Voir les pages de manuel d'apt-secure(8) pour la création des dépôts et les détails de configuration d'un utilisateur.
    Thank you in advance for your help.
    Have a nice day !
  • vlad88sv
    vlad88sv Posts: 0
    edited June 2021
    Err:13 https://linux.teamviewer.com/deb stable InRelease
     403 Forbidden
  • Cybermax
    Cybermax Posts: 1 Newbie
    edited June 2021
    Seeing the same here, only difference is that it uses the ipv6 address instead: 403 Forbidden [IP: 2600:9000:215d:f200:1c:3aaa:b100:93a1 443]
    If you try to access https://download.teamviewer.com/ it redirects to https://dl.teamviewer.com/releases and it hits a 404.
    Maybe some sort of webserver problem?
  • TimRiker
    TimRiker Posts: 3 ✭✭
    edited June 2021
    It is not working for me on Ubuntu 18.04
    $ sudo apt update
     403 Forbidden [IP: 2600:9000:20c5:6800:1c:3aaa:b100:93a1 443]
    E: Failed to fetch https://linux.teamviewer.com/deb/dists/stable/InRelease  403  Forbidden [IP: 2600:9000:20c5:6800:1c:3aaa:b100:93a1 443]
  • gb9130
    gb9130 Posts: 3 ✭✭
    Why are Teamviewer updates failing on ALL (30+) Linux laptops?
    How can I get the non-Teamviewer updates?
  • gb9130
    gb9130 Posts: 3 ✭✭
    If the issue was fixed on April 16th, why am I getting the same problem now (June 6th)?
  • ParrishS
    ParrishS Posts: 2 ✭✭
    Teamviewer repo is at linux.teamviewer.com. I am getting an access denied from there anywhere I try and browse as XML. Repo problems?
  • l0f4r0
    l0f4r0 Posts: 8 ✭✭
    edited June 2021
    Same thing here on Debian 10 (stable).
    # apt update
    Err:6 hxxps://linux.teamviewer[.]com/deb stable InRelease
     403 Forbidden
    E: Failed to fetch hxxps://linux.teamviewer[.]com/deb/dists/stable/InRelease 403 Forbidden
    E: The repository 'hxxps://linux.teamviewer[.]com/deb stable InRelease' is no longer signed.
    No better after typing `̀# teamviewer repo default`.
    Manual navigation to hxxps://linux.teamviewer[.]com/deb with my browser leads me to an error XML page stating "AccessDenied".
    NB: I've sanitized the links above because my post is not authorized otherwise...
  • l0f4r0
    l0f4r0 Posts: 8 ✭✭
    1) Because of an issue on the repo side...
    2) Just comment your TeamViewer repo in the meantime (or use the dedicated command `teamviewer repo disable`)
  • Chalancito13
    Chalancito13 Posts: 0
    I was having problems with the update of my linux distro(lubuntu 20.04), the error message was weird: "check your internet connection" because i have ethernet connection besides wireless.
    I went to debug the issue and finally found, from the "sudo apt update":
    Err:8 https://linux.teamviewer.com/deb stable InRelease
     403 Forbidden [IP: 2600:9000:20d1:5600:1c:3aaa:b100:93a1 443]
    and also:
    E: Fallo al obtener https://linux.teamviewer.com/deb/dists/stable/InRelease  403  Forbidden [IP: 2600:9000:20d1:5600:1c:3aaa:b100:93a1 443]
    E: El repositorio «https://linux.teamviewer.com/deb stable InRelease» ya no está firmado.
    N: No se puede actualizar de un repositorio como este de forma segura y por tanto está deshabilitado por omisión.
    I had to remove the teamviewer app, then all was fine with my update.
    Please check and fix this.
    Thanks for all the people that now has problem with this issue.
    Johny.
  • myviolinsings
    myviolinsings Posts: 3 ✭✭
    I have been getting the same error this week on Ubuntu 20.04:
    E: Failed to fetch https://linux.teamviewer.com/deb/dists/stable/InRelease  403  Forbidden [IP: 54.230.72.17 443]
    Please advise.
  • dmgpage
    dmgpage Posts: 2 Newbie
    Same problem:
    E: Failed to fetch https://linux.teamviewer.com/deb/dists/stable/InRelease  403  Forbidden [IP: 65.9.57.63 443]
  • dmgpage
    I tried to run above mentioned: "sudo teamviewer repo stable ; sudo apt-get update -y", but that did not help.
  • Dom
    Dom Posts: 14 ✭✭
    Same problem with a different date!!!
    TeamViewer... Please Update the Security Certificates for your Repository so our Updates in Linux are not broken because of your bad form or oversight!!! So far the only solution is to disable or delete the TeamViewer Repository and wait for TeamViewer (cough... working under pressure) to fix it on their end and enable the repository or reinstall the TeamViewer Linux .Deb (or other suitable installer) to add the Repository back at a later time once TeamViewer get it together. With what we pay to use your service... come on... this is just bad form!!!
  • l0f4r0
    l0f4r0 Posts: 8 ✭✭
    # apt update
     403 Forbidden [IP: 52.222.174.18 443]
    E: Failed to fetch hxxps://linux.teamviewer[.]com/deb/dists/stable/InRelease 403 Forbidden [IP: 52.222.174.18 443]
  • l0f4r0
    l0f4r0 Posts: 8 ✭✭
    # apt update
  • robv
    robv Posts: 2 ✭✭
    It started happening a few days ago and is still failing for me.
    Ubuntu 20.04 LTS
    Err:5 https://linux.teamviewer.com/deb stable InRelease
     403 Forbidden [IP: 52.85.170.17 443]
    E: Failed to fetch https://linux.teamviewer.com/deb/dists/stable/InRelease  403  Forbidden [IP: 52.85.170.17 443]
