I have a personal license only. I'm literally trying to connect to the computer across the room and it keeps kicking me out. Anyone know how to fix it? Thanks
Same here
Same. Literally have never used it for anything other than getting help from a friend or vice versa, and connecting with my phone to access files while out and about.
I AM NOT A BUSINESS !.. so why do i keep getting booted out everytime i try to log into my sons pc?
I am having the same issue and am using the application for the same reason. I'll bookmark this thread to see if there is any resolution.
I have the same issue, it only recently started happening and oddly enough, from my phone i can connect fine to both computers (one running ubuntu 20.04 and teamviewer host and the other windows 10 and teamviwer. It seems to only be an issue when i try to connect from my main computer.
I get the same only work on my family computers so what's up Teem Viewer
I have been using team viewer for many years now without any issues. over the past couple days, i have been getting timed out after 50 seconds and when i try to go back in it tells me i have reached the timeout and have to wait a certain amount of time before trying again. any leads????
Got me too. This is the second time in the past year this has happened.
Honestly for non-commercial use I'm just going to swap over to **third party product**. I'm tired of dealing with team viewers **bleep**.
Thank you TEAMVIEWER for your timely response with a reset link. I have actioned the link and will await the reset activity completion.
I am still interested to know if anyone has an answer to my question.
I have the FREE version which I DO NOT use for ANY commercial reasons. Mostly I use it to help a friend who is legally blind and lives 1000 miles away. I have been using the free version for over 10 years and never had a problem until the last month. Now, every time I try to log on to help my friend, I connect, and then 20-30 seconds later TV disconnects and show a "session times out " message. I have uninstalled and reinstalled it; did not help.
What the heck is going on?
By the way, I am 77 years old and I do not nor ever have used TV for commercial use.
I use TV to connect to my home desktop which isn't connected to a screen. The desktop is to backup my home photos and files. I also use TV to help my mom with her computer across the country. Suddenly after being connected for one minute I get the error that the session has timed out. If I try to reconnect it says that immediate connections are blocked. It takes about 5 minutes before I can reconnect again. Is there something wrong with my account?
I only use free version to access my home computer for files remotely and the session keep closing out
I'm getting the same thing on my PC as soon as I launch an app via citrix. Started on Sunday and previously I've had no issues for weeks.
Clearly Teamviewer either ignores the forums, can’t be bothered to respond or are so busy trying to fix what ever the problem is that they don’t respond. Anyway, I think trying to resolve this vis the forum is a waste of time. Have a look on the support page and call them tomorrow when they are open. I tried to send the ‘I’m playing Fair’ form, but it asks for your postcode and them rejects a U.K. postcode because it is not only digits.
I am now getting kicked off either computer, one from home or work after only about a minute or so and I've been using the free service for about a year or so! What gives?
This is happening to me too - haven't used TV in a while but now sessions get disconnected after about one minute. I've been a TV user for years.
Hello Support. I have filled out your "reset my id" form 3x now, and i have gotten back 3x that my id can been fixed and the incorrect flag removed. Today was the 4x time i have tried and it is still broken. I am following all of your rules, i am not a business. I am connecting to me literally across from me in the same room, not commercial nor work related. Please do not spam me with the same response about from ester, i need a real answer hy after 3x you are still flagging my account. i tried calling but that tell me to goto your forum. please respond and fix this .
same problem here! the last 30 days have been **bleep** trying to get support to answer the phone or emails.
Hi, I am having the same issue with the session being timed out after 1 minute even though I don't use TeamViewer for commercial purposes.
Could you advise how I can get this resolved or where the 'reset ID' button is?
Dear officer,
This is Xiaohang Shao and my account is [removed per Community Guidelines].Because of the corna,I have to stay at home .I need to remote control my classmate computer, and transfer my files to her computer.I don't know why it always disconnect and told me testing the business working, could you help me about this as soon as possible ?
thanks a lot and best regards,
Xiaohang
I have tried going through the reset ID 3 times; however, I cannot get past step 1 (filling out the form). Clicking on generate a PDF does anyone have a suggestion as how to make this work?
Again, I have NEVER EVER used TV for a commercial purpose and have no idea why I would get flagged.
Hello @Searcher43
Thanks for your post.
If the form does not submit, it means there is an error that was entered on the form.
Please ensure your information is correct, and the TeamViewer ID of the device that was flagged was entered correctly.
Josh P.
Senior Community Moderator---
i WILL be resubmitting this a 4x time. Thank you
I'm using the free edition to help a couple of friends and family member and recently I get disconnected after only 3 minutes. What is wrong, I'm I being flagged as commercial ? how do we fix this ?
Thx
I all of a sudden Keep getting timed out and then it says I'm blocked for a minute, but unable to get back on. This has never happened before.
Hi, yesterday I received that message that my account was flagged as "commercial use". But I would like to explain that it is definitely not a commercial use. I have the free account on TeamViewer for many many years already and everyone that asks me about a tool like this, I always recommend TV.
So, I'm trying to submit a request to reset that and explain that is not commercial use, but the form on the link https://www.teamviewer.com/en/reset-management/. Does TV accepts to revert the configuration? Or, at least, allow me to connect for few minutes, couple times, in order for me to find another way to have access to my personal machine?
Thank you!!
Rodrigo Goncalves
Hi
i have a question , why I'm getting kicked out after connect to a session ?
a massage pop up and says connection blocked after time out
please explain this to me, what does that mean ? and whats the solution ? how can i fix it ???
FYI i have a free license .
Thanks and regards
