1260261263265266412
  • I submitted my form to have my access reset to personal use yesterday and had an email today saying it has been reset. I haven't had a chance to try it yet but hoping that it's sorted out now.
  • xorxfon
    xorxfon Posts: 2 ✭✭
    I would like to see a one time Non-Commercial payment to unlock the program so our time is not wasted and more importantly the company time is not wasted on someone constantly reseting the free profiles. Just a one time fee that lets TeamViewer know that I use the program on the regular but it is not for commercial use so there would be no monthly charges. Or just charge a monthly non-commercial license fee and watch the customers bleed away.
  • DvilDove
    DvilDove Posts: 1
    I use team viewer to help my parents and one friend, yet I keep getting timed out.
    Where can I find the time limits, as well as how much I have used?
    Can anyone explain this to me or do I need to look for another solution?
  • ralnavman
    ralnavman Posts: 7 ✭✭
    I'm getting this for the 2nd time round.....it's really infuriating. Especially as I was 'warned' last time I posted the problem. I was contacted by someone (probably support) who apologised for the 'warning' saying it was an error but that I had to complete a form. I duly did that but I didn't get yet it was fixed.
    So I've been using it for about a week and bang, I'm chucked out again!! I've completed the form (AGAIN) but that was 2 days ago and I haven't received any email. It would seem that there is a general issue which they can't fix but it is getting really tiresome, I can't access my personal machines round the house (they don't have monitors etc..).
    And the weekend is approaching.....
  • jfbernard
    jfbernard Posts: 1
    Hi to all,
    I'm get timeouts after very short connections, and afterwards I get the error window "Unable to connect" with the message "Connection blocked after timeout" etc.
    The message does NOT say "Commecial use detected" though. Is this the same problem anyways?
    Can you please help?
    Thank you so much!
  • jugdeep
    jugdeep Posts: 1
    I'm getting the same issue too
  • Jami1
    Jami1 Posts: 1
    I'm getting the same issue.
    Anyone know how to fix this?
  • larryamay
    larryamay Posts: 2 ✭✭
    I am going to fix it after months of abasing myself in frint of these people, I am going to immediately Un-install, hope it does not screw up my computers and then install one of the other remote desk-tops that will work. Adios Teamviewer after many many years of enjoyment.
    Larry May
  • linuxlore
    linuxlore Posts: 4 ✭✭
    I wouldn't bank on it. I did that about a year ago, and thinking that I had been flagged commercial again with this timeout issue I did it again. I was told that I was already non-commercial a couple of days ago - hence assuming this is something bug related. It also tells me "Connection blocked after timeout", and "Your license limits the maximum duration to a partner, immediate reconnects are blocked. Please try later or upgrade your license". This wouldn't be as bad if the session was longer than about 15 seconds or so, and if the block actually was removed when quoted (which tends to be about a minute later) rather than just getting the same message that indicates I will be unblocked if I want another minute (all be it only for another 15 seconds!).
  • Ninoninixion
    Ninoninixion Posts: 1
    having the same issue, connection drops out/ timesout after a few seconds and doesn't let me connect anymore for X amount of minutes (which increases each time i try to reconnect) years i've used this software and got others onto it aswell but this issue can't easily be resolved as i cannot submit a ticket and not much help actually seems to be happening from the looks of this post, i may have to ditch this software and recommend another that actually works as described without such hiccups as this is not the first time i have had issues with the software, such a shame too.
  • sjt3
    sjt3 Posts: 1
    Is this something new, just started the other day. I have been using team viewer for along time, and never had this issue
  • RemoteGradStudent
    RemoteGradStudent Posts: 1
    edited April 2021
    Me too. I've been using Teamviewer every week since March 2020 and I just started getting this issue today (Connection blocked after timeout). Very frustrating! I seem to be able to connect again briefly if I reinstall the app or sometimes when I restart. Was anyone able to find a solution?
    Edit: I realized Teamviewer has been/is working fine on my Windows machine. Seems like this is a Mac issue.
  • Tinbum
    Tinbum Posts: 2 ✭✭
    I don't know why all the messages on timeouts are being merged here as i've followed the instructions to send the PDF and received the acknowledgment but still get the timeout message. The message also says connection will be blocked until xx:xx but you still can't reconnect until a lot later.
    Lets actually have a reply from teamviewer- they must actually realize this is a bug or are they wanting everyone to leave?
  • Hunven
    Hunven Posts: 3 ✭✭
    Hello, I'm using the free version of TeamViewer so I can jump into my two home computers while at work. The problem I'm having is all of the sudden, when I get into one of my computers, I have only a minute or so before the session times out. Then it blocks me from getting back into that computer for a few minutes. Is there any way around this?
  • JoshP
    JoshP Posts: 895 Community Manager 🌍
    Answer ✓
    Hello @Hunven
    Thanks for your post.
    Connections to or from work computers, for any purpose, is considered commercial use.
    This is why the connection is limited. A license would be required to make connections to or from a work computer.
    More information is here:
    Josh P.
    Senior Community Moderator
  • Hunven
    Hunven Posts: 3 ✭✭
    Ah ok that makes sense. I'll try connecting from my personal phone then. I don't believe I've had these connection issues through there. It's a bit of a pain to travel through the phone, but I understand the rules that are in place. Thank you for the clarification!
  • imgkc
    imgkc Posts: 9 ✭✭
    I know I like many others are using the free version of TeamViewer. For me it seems as if TeamViewer doesn't care about us. I again like many others have been having connection timeout issues. We've posted in the community forum and are unable to help each other. We need some assistance from the TeamViewer support team but all we hear is nothing.
    How about some help TeamViewer.. If by ignoring us is your way of enticing us to purchase a license guess what, it's not working.
    We want to support your product but you're not doing anything to make us feel welcome. Even chat based support would be welcome.
  • Crosstrax
    Crosstrax Posts: 1
    I am having the same issue but it is not a work computer, it is my personal computer and it just started happening. It have received no message that it has been flagged as commercial so what is causing this?
  • Hunven
    Hunven Posts: 3 ✭✭
    Are you doing it from work? It looks like those guides state that if you are doing it from a corporate network, it could be flagged as well.
  • redlands
    redlands Posts: 1
    I am experiencing the same issue. It started happening out of the blue. I am using the free license version in my home between 3 separate computers. All are on my private home network. I don't have the ability to use a KVM switch due to distance limitation. I have been using the program for probably a year and a half and was not having any issues until the other day when I had logged into the TV program to do an update on my 2nd pc's windows op system. Within a minute the connection timed out and I couldn't get back in for several minutes with that noted message to upgrade to commercial.
    How do I de-flag my account as being commercial?
    Any help would be appreciated!
  • Terrie
    Terrie Posts: 2 ✭✭
    I have a free TeamViewer account for personal use only. For the past several days, I have been able to successfully connect to a partner account (my father's computer), but TeamViewer times me out after less than a minute, with the message, "Your TeamViewer Session has timed out and will be closed." My father and I have attempted to reconnect numerous times over the past several days and have not been able to have sessions lasting beyond a minute. Please advise. Thank you!
  • Tinbum
    Tinbum Posts: 2 ✭✭
    edited April 2021
    Tinbum was warned for this.
    Warning 0 points Message from a moderator. This is NOT a warning, just a note. This topic has already been answered here : https://community.teamviewer.com/English/discussion/8284/commercial-use-connection-time-out/p1 You can request the reset for your TeamViewer ID here:
    https://www.teamviewer.com/reset
    Thanks and have a great day!
    My post says I have been warned for the post by a moderator and says this has been answered and gives a link to the first page of this topic. I have done that already as I said in my post.
    Please solve this instead of telling me to do something I and many other people have already done that doesn't solve it.
  • Radiotwo
    Radiotwo Posts: 1
    For the last week when I try to use teamviewer I can connect then get this pop up:
    Your teamview session has timed out and will close.
    and drops the link
    Can any one tell me why this is dong this?
    Many thanks
    Steve
  • mikeyb
    mikeyb Posts: 3 ✭✭
    On logging in 0n 22 April 2021, for no reason at all, TeamViewer logged me out of the account after 1 minute, with the message “Connection blocked after timeout” and “You license limits the maximum session duration to a partner. Immediate reconnects are locked. Please try later or upgrade your licence”. This message repeated every time I logged in.
    On investigation, I discovered that this was due to “suspicion that Teamviewer is being used for commercial purposes”. That is a nonsense! I have been using Teamviewer for personal use almost 2 years and have NEVER had reason to use it for commercial purposes. I only use it for 1 to 2 hours per week on average, and I am a retired person with no commercial Interests whatsoever.
    I chatted with your sales team, who kindly sent me a link to get the account reinstated. I followed the process, completed the form, signed it and pdf’d it. On trying to submit it, the message came back “The form can only be sent in pdf format”. I tried several times, with the same result. The form IS in pdf format, but your system won’t accept it.
    So after going through all of this I still don’t have TeamViewer.
    Please could you resolve the problem, as this has gone on for far too long.
  • mikeyb
    mikeyb Posts: 3 ✭✭
    Any help with this problem would be much appreciated.
  • Michaelrjones
    Michaelrjones Posts: 1
    edited April 2021
    How do I unblock my connection to my desktop computer. I have had free service connection for several years.
  • pk77777
    pk77777 Posts: 2 ✭✭
    I'll add my complaint to this list of TIMEOUT problems. I will make it clear that I DID NOT receive a message saying that commercial use was suspected. TV simply timed out starting around Apr. 18 or so. I use TV ONLY to support my elderly mother who is not very computer savvy and not for any commercial use.
    I did get a response from Fiona at TV but she only suggested the 'request a reset after suspected commercial use' route even though I was clear that I did not receive a commercial use warning - just a timeout.
    TEAMVIEWER PLEASE HELP!!! Many of us need this to support family members, especially during Covid!
  • whlytle
    whlytle Posts: 1
    I have been using TeamViewer since 2010 for "free" at first and later. I was a consultant and had my clients purchase TeamViewer so I could access home computers while traveling or working from home. Usually my clients did not have an issue with this. It was very convenient. Originally, Iooking for a service that let me access my personal computers when not at home or even across the house was how I discovered TeamViewer and in turn brought in several paying customers who in turn spread the word. That is advertising.
    I understand that TeamViewer needs to make a profit and can't afford to spend time serving non-paying uses. But they should be honest. If they don't want non-paying users they should just say they will no long provide free services, or If it is a bug, just say it is a bug. I read in this forum that submitting the reactivation form has not worked for some apparently. I have not seen that anyone who submitted the signed request got back on the forum and said that fixed their issue. Maybe I missed those. And why doesn't the pop-up state to go to the forum or give a link to re-activate. I had to search this issue, which brought me to this forum.
    I've submitted the pdf request form with my signature. The form actually timed out and quit on me twice. Once when I stepped away from my computer because my wife had a question and once again filling in the description box. Also the form and reference links seem to be related to “Commercial” use. My time outs and blocks say nothing about "commercial use". The replies I've seen from the community moderators seem a little testy. So much for "the customer is always right". But then technically non-payers are not customers.
  • mmyers
    mmyers Posts: 1
    edited April 2021
    Going to add my complaint to the list as well. I have been using TV for years so that I can connect to my parents computers when they need support. I can connect to my mother's computer with no time out error, but when I connect to my dad's it times out whether its from my computer or my moms. My parents computers are on the same network at their apartment so please explain to me why I only get a time out on just the one computer. I have checked my license and it is still set as personal use so a reset will do nothing but waste someone's time.
    Please fix this issue or tell me what I can do on my end. I have checked all 3 computers are running the same versions. I have uninstalled and reinstalled TV on my Dad's computer with no change.
    Please someone from TV address this issue.
    Thanks,
  • sabrownie
    sabrownie Posts: 4 ✭✭
    I followed the instructions on the page linked below, printing out the .pdf, signing it, scanning it and uploading it as requested. They acknowledged receipt of the signed document and said my account would be reactivated as a "personal" account within 2 business days. It actually took them less than 1 day to respond via email stating that my account status had been reactivated. Remember that every computer has it's own TeamViewer ID (2 per connection, source pc and remote pc) and it may be necessary to submit the same document for the remote computer ID also. Hope this helps... good luck,
    https://www.teamviewer.com/en/reset-management/
