Seeing issue with std:logic_error in 15.14.5
juancuero
juancuero Posts: 2 ✭✭
When trying to apply a password through the cmd line I see:
sudo teamviewer --passwd password
terminate called after throwing an instance of 'std::logic_error'
 what(): basic_string::_M_construct null not valid
/opt/teamviewer/tv_bin/script/tvw_extra: line 77: 12507 Aborted         (core dumped) "$TV_BIN_DIR/teamviewerd" --passwd "$pwd"
unknown response
Is this unique to version 15.14.5? I haven't seen it before.
  • VinceS
    VinceS Posts: 1
    I have the same problem recently, and haven't seen it before. It is very troublesome, since it means that I can't change the login password remotely. Is there a way to downgrade to a previous version 15 if this can't be fixed?
  • CryingSysAdmin
    CryingSysAdmin Posts: 0
    I have the same issue, I have sent a ticket to Teamviewer support too. Will update another comment if I get a reply.
  • rolandg
    rolandg Posts: 66 ✭✭
    same here with teamviewer-host 15.16.8 on CentOS 7
  • DaveJ4822
    DaveJ4822 Posts: 1
    Hello, I am having this same issue with Ubuntu Xenial 16.04 and Teamviewer 15.16.8
    Please help!!
