MacOS keyboard shortcuts in Eclipse not working
Paul_NZ
Posts: 2 ✭✭
I'm connecting from MacOS TeamViewer 15.13.7 to a Windows 10 PC running Eclipse. Some of the eclipse keyboard shortcuts are not working such as ctrl-space for content assist and ctrl-/ for comments. However other ctrl shortcuts do work fine, such as ctrl-H for search. These shortcuts all work fine when input on the actual Windows PC keyboard so it's not a config issue in Eclipse. Is there an issue with TV not sending certain keyboard multi key combos?
Exact same problem (TeamViewer 15.17.6 to Windows 10). I find that adding SHIFT helps sometimes: control-shift-S to save; control-shift-H to search. But control-shfit / does not comment highlighted code. Very frustrating.
