12345679»
  • Hi everyone, Hi @_Andreas_ ,
    Does anyone know if the Teamviewer client now works on Mac ?
    Everything is installed correctly on mine but the client does'nt launch.
    Thanks.
    Patrick
  • mircea_c
    mircea_c Posts: 113 Staff member 🤠
    Hi @PatrickMignon
    For now, is not working to connect from a MacOS to a Synology device.
    Mircea
    Tech Support IoT
  • When will macOS be supported?
  • mircea_c
    Hi @raptile
    Unfortunately, for the moment, we do not have an ETA for the MacOS support.
    Mircea
    Tech Support IoT
  • MrNew666
    MrNew666 Posts: 1
    hi @PatrickG
    I have the following problem when connecting thru Teamviewer to my NAS DS220+.
    I have installed TEamviewer on NAS and successfully established the connection thru Teamviewer client to the NAS. But there is a security issue poping up when connection (see pic below), that says that the name on the certificate in invalid or does not match the name of the site. I assume this means that the connection is not secure when connecting thru teamviewer because of the issue with certificate. My certificate installed on NAS is valid and issued by Lets Encrypt. I can actually connect, by its not secure. Would appreciate if you could help me make the connecton secure.
    Can u pls furnish me with the solution what to do in order to pass this certificate issue successfully? thx
    Simon
    certificate problem
    certificate problem backup image
  • On my Synology DS215+ dith DSM version DSM 6.2.3-25426 Update 2, TeamViewer doesn't work.
    It has never worked.
    When I run it, it shows a blank little window wi no links or button except for the "Third party licenses" and "www.teamviewer.com" links on the bottom.
  • mircea_c
    Hi @OnSite
    I forwarded your issue to my colleagues from support.
    They will get in contact with your for further checkups
    Mircea
    Tech Support IoT
  • mircea_c
    Hi  @MrNew666
    I forwarded your issue to my colleagues.
    They will get in touch with you for more details.
    Mircea
    Tech Support IoT
  • mahisri
    mahisri Posts: 2 Newbie
    Any ideas on how to fix this? It used to work but presents blank screen after update:
  • mircea_c
    Hi @mahisri
    The device is assigned to your account or because the interface is not loading you were not able to do it? I am asking this because if is not assigned you can try like a quick fix if it is possible via the “Nearby contacts and devices” function for adding the device.
    On some devices it seems that the Agent interface is not loading, we are aware and trying to fix it.
    Tech Support IoT
  • wschlich
    wschlich Posts: 7 ✭✭
    edited March 1
    After almost a year, still no news with TeamViewer 15.15.5 on Linux! :-(
    Connecting to TeamViewer IoT on a Synology NAS results in "Authentication rejected".
  • Guig67
    Guig67 Posts: 1 Newbie
    edited April 11
    Hello everyone,
    I'm facing problem with Teamviewer package on a Synology DS220+.
    When attempting to "Assign" my NAS to my Teamviewer account, i have this message :
    Even with the correct password for assignement, i get this error.
    For information, i have already added 2 other NAS, DS220+ and DS118 without any problem !
    I'm thinking that it comes from the package ...
    Any idea, please ?
    Thanks in advance !
  • mircea_c
    Hi @Guig67
    If you already have 2 NAS added, the issue could be that you do not have any Synology Endpoints left for assignment.
    To support you more, the first two devices are free of charge. For adding more devices or to get more information please visit here
    Mircea
    Tech Support IoT
  • DoubleM
    DoubleM Posts: 1 Newbie
    I could add my NAS by using Teamvier from my PC and use the “Nearby contacts and devices” function 😀
  • Spaldo
    Spaldo Posts: 2 ✭✭
    edited May 1
    I am also getting the same issue with the blank box. I have never installed the app on the Synology. The local search method on my windows machine finds the server, but, I cannot login as I do not know the password nor have been able to link it to my Synology account :(
    Anyone have any ideas to make it display? I have tried checking & unchecking the security box - cross site protection.
    I am running: Synology DS214 (MARVELL Armada XP MV78230) running DSM 6.2.4-25556. TeamViewer 2.8.17 version on Synology
  • mircea_c
    @Spaldo
    On some Synology devices seems that the TeamViewer Agent is showing a blank page.
    If you are in the same LAN network with the device, open on the PC TeamViewer and try to add the device via “Nearby contacts and devices” function.
    The device will get assigned to your account without the need of password. If the device is already added please try again to add.
    Mircea
    Tech Support IoT
  • chriszh
    chriszh Posts: 1 Newbie
    How the teamviewer app on synology could be reseted?
    Whats the path of the Settings File?
    Because only delete and reinstall the app is not solving my problem.
  • mircea_c
    Hi @chriszh
    Could you please give more details with you problem?
    Mircea
    Tech Support IoT
