Teamviewer stops working GetWindowText (User32.dll) Function
I have developed a C# code which access to user32.dll and it is using GetWindowText function. The code is working properly when Teamviewer is uninstalled on Windows 7.
However if you install Teamviewer, the code can not retrieve the text of control in window with GetWindowText function. How can I solve this problem ?
Well I have resolved the issue. I was calling also dialog file class with the function FindWindowEx by the class name #32770.
This class type is used also by Teamviewer(TV) quick support user interface. When I run my code, there is a intervention to the interface of TV and blocks of working user32 functions.
To solve the problem I have called the FindWindow function with class name and control name so that there is no intervention to the TV and problem solved.
