How do I remove Teamviewer MultiOutputDevice?
What is the purpose MultiOutputDevice? Tried to search about it but couldn't find anything.
I tried to remove it and tried to uninstall Teamviewer but it's still there in volume control
Using macOS Big Sur 11.4 and latest Teamviewer
I have the same problem. After deleting the program, the device remains. How do I delete it??
Here's the solution if you are going to keep using TeamViewer:
This _might_ help, if you have totally deleted TeamViewer.
5 -
I deleted the app. After deleting the folder: TVRemoteAudio. driver. But the problem remained.
@Adfggd4543ds If you find that, after uninstalling, there is still a TeamViewer MultiOutputDevice left on your system, you can remove it using Audio MIDI Setup (Applications -> Utilities). Please note that it is not advisable to do this while TeamViewer is running.
