Session code is empty
Jayla
Jayla Posts: 5 ✭✭
I use customized module of QuickSupport. But it show nothing or just a character s in session code field. Why session code not show properly
    Does this happen on all or just on one device?
  • Jayla
    Jayla Posts: 5 ✭✭
    edited July 2021
    I tried three computers and it happen on two of them.
    Could you provide us with the following information regarding the impacted devices:
    • the exact OS version
    • the exact TeamViewer version
    Also, please check if ports 5938, 443 and 80 are open within your network.
  • Jayla
    Jayla Posts: 5 ✭✭
    The version of TeamViewerQS is 15.19.5.0
    Workstation 1: win server 2016 64 bit
    This one works
    Workstation 2: win server 2016 64 bit
    Workstation 3: win server 2012 64 bit
    These two didn't work
    edited July 2021
    I asked our engineers and they recommended downloading a fresh version of the QuickSupport from the Management Console and try again.
  • Jayla
    Jayla Posts: 5 ✭✭
    I download it again but the issue still persist. 😥
    Did you check the ports as recommended above?
  • Jayla
    Jayla Posts: 5 ✭✭
    Yes, I open these ports but it still show empty.
    In this case, opening a ticket will be the last resort.
    Our engineers will have to look at the issue closer.
    I recommend adding the log files to your ticket.
