invalid password, please try again
karasu79
karasu79 Posts: 1
edited July 2021 in General questions
- teamviewer free version
- New dell laptop with win 10 pro
- from any pc
- antivirus removal attempted
- attempted firewall deactivation
- attempted reinstallation
- attempted with execution only
- attempted refresh password
- attempted activation of personalized password
what else can i check?
  • smtassini
    smtassini Posts: 0
    Hi. I can't sign into my remote PC - first time I've has this problem. First it would not recognize the computer until my wife got home and "woke up" the sleeping computer. Now it states the remote PW I have entered is incorrect, but it's the one I have recorded and the one my wife states is on the screen. Now what?
    Hello @smtassini,
    Are you connecting via an unattended access password (preset in the options) or via random password?
  • USAFmike76
    USAFmike76 Posts: 2 ✭✭
    I'm trying to connect via the saved computer I have in my group. worked fine earlier. now it's not. password is invalid. it wasn't 3 hours ago. I think ithe pc may have rebooted but why would my saved password it had me entered change?
  • USAFmike76
    man. this place is helpful....can't find an answer to the same issue. other than uninstall and reinstall. what a bunch of trash this program is.
    I recommend setting up a new password in the saved computer.
    You can change the password of the devices you have saved into your Computer & Contacts list, with the following procedure:
    1. Open TeamViewer
    2. Right-click on the device
    3. Select Properties
    4. Edit the password in the dedicated section
    Also, make sure the password is correctly set in the options of the remote computer:
    Under Extras --> Options --> Advanced --> under Advanced settings for connections to this computer --> Personal Password you can type in your password. After confirming it by repeating your chosen password, click OK
