Problem with join to a new meeting - errors
ssu11
ssu11 Posts: 6 ✭✭
edited April 2023 in Meeting Forum
Hello, I have a problem when i try to connect to new meeting.
I create meeting on first computer, and next i try to connect on other computers.
I write a ID Meeting, click Join and after 5s new window closed.
I tried that on few laptops and always was the same problem.
In logs files i see only error like below:
[logs files removed per Community Guidelines]
Where is a problem?
I have the latest version and i use commercial license.
Thanks in advance.
ssu11
  • Justin
    Hello @ssu11,
    Could you please open all the ports TeamViewer uses, as it seems that those are blocked?
    Check if the ports are open and let me know if the issue persists.
    Justin
    German Community Moderator
  • ssu11
    ssu11 Posts: 6 ✭✭
    Unfortunately. The problem still exists.
    What else can i check?
    The problem occurs on all computers, different networks.
  • ssu11
    ssu11 Posts: 6 ✭✭
    edited August 2021
    The problem is only with the application: TeamViewerQJ
    Nazwa aplikacji powodującej błąd: TeamViewer.exe, wersja: 15.21.6.0, sygnatura czasowa: 0x612913de
    Nazwa modułu powodującego błąd: TeamViewer.exe, wersja: 15.21.6.0, sygnatura czasowa: 0x612913de
    Kod wyjątku: 0xc0000005
    Przesunięcie błędu: 0x002f7d20
    Identyfikator procesu powodującego błąd: 0x1b64
  • ssu11
    ssu11 Posts: 6 ✭✭
    Any ideas? ...
  • Justin
    Hello @ssu11,
    We can confirm that we can reproduce that issue and our development team is also working on it.
    I apologize for the inconvenience caused.
    Justin
  • ssu11
    ssu11 Posts: 6 ✭✭
    Ok, thank you for your reply Justin! 🙂
    I look forward to your answer.
  • ssu11
    ssu11 Posts: 6 ✭✭
    edited September 2021
    Hi @Justin , do you have any news ? :)
