TeamViewer MSI via deploy fails in Windows 10, works under windows 7
I have a script msiexec command to install a deployment msi from our corporate TV poortal.
I have tested and confirm this command works under Win7
msiexec.exe /i ".\D-TeamViewerDeploy\HostOnlyTeamViewerDeployPackage.msi" /qn CUSTOMCONFIGID=<Deployconfig code> APITOKEN=<Deploye API token> ASSIGNMENTOPTIONS="--grant-easy-access --reassign"
When I run this in WIn7 x86 it works as expected
When I run this under Win10x64 it fails to run
When I change the /qn to /qb I get this error:
"This installation package could not be opened. Verify that the package exists and that you can access it, or contact the application vendor to verify that this is a valid Windows Installer package."
TeamViewer can be installed via the msi file interactively, to the file is not corrupted.
Try activate more verbose logging for the MSI installation. In the resulting logfile you should get more information on the error.
