Setup issue teamviewer-iot-agent on RevolutionPi
nico_asdasfdfer
nico_asdasfdfer Posts: 1
Good day,
I am currently trying to set up the TeamViewer client on a RevolutionPi Core (RevPi), but I am having some problems.
I have already created a TeamViewer account and wanted to set up my RevPi with this account via sudo teamviewer-iot-agent setup. After entering my EMail address and the corresponding password it takes a while until then a message appears that the configuration cannot be done.
Attached is a screen shot of the error message. The RevPi has a continuous internet connection.
I look forward to your feedback and hope you can help me.
Best thanks and best regards
Nicolas
  • mircea_c
    Hi @nico_asdasfdfer
    I have created a support case with your error.
    My Colleagues will get in touch with you soon.
    Mircea
    Tech Support IoT
  • Daevis3
    Daevis3 Posts: 1
    edited October 2021
    hello, i have a similar problem, i followed the steps indicated in the platform adding the token manually, in the forums i found that using "setup" but at the moment i can't add my device. it is a RPI3 with debian. any idea how to solve it?
    JuanD
  • mircea_c
    @Daevis3
    From the print screen seems that the device is already assigned to your account.
    You can run "sudo teamviewer-iot-agent info" which will print the username where the device is assign to and the TeamViewer ID.
    Mircea
    Tech Support IoT
